I just got my Xperia Arc last month. But recently this problem came up. There is the notification when a SMS comes in. But when i open to view it, it is not there.
I tried deleting the conversation and it was fine. However i'm not sure if this is a proper solution.
I searched the internet but there was no similar problem to what i am having. Are there anyone else having this kind of problem? Maybe u found another solution this it?
Solved! Go to Solution.
check your date and time of the phone.. most probably the date and time is wrong..
heya
do this ( will delete all messages and its settings)
settings> applications> manage applications> all > messaging> clear data
see if problem exists
Hi, the other suspect is Messaging app downloaded from Android Market (if you have). If not, follow Nabeelraza' suggestion.
The time was wrong. Thanks a lot:smileyhappy:
you'r welcome
