my older phone's memory card was a 4 gb and i was always able to format and reach it as a X: drive on windows. but neo doesnt let me use it the same way. i can only access it as a mobile device named xperia neo on MTP mode. on msc mode, the card is found but can not be accessed. can someone tell me if i have a problem here? do everyone's neos behave the same way about memory cards?
Solved! Go to Solution.
try this
settings -> sony ericsson -> connectivity -> uncheck 1) install pc companion 2) auto connect in msc -> tap on USB Connection mode -> MSC
now connect your phone to your computer
wait then drag down the notification bar and tap on mount SD card
dear god, so much thx. i didnt know that. i hate that small notifications area and never saw that notification about mounting til you said. done!
Now don't forget to install the backup & restore app, just in case and the other methods to backup everything
