HI,
I've been having the some problems with the screen alignment on mine X2 since I had one spot on my Xperia X2 screen that was dead, so can someone post the calibration data please?
Thank you,
Sujith
Solved! Go to Solution.
OK, here are the values I got:
"523,512 163,888 161,127 894,141 857,880 510,883 515,135"
Let me know if you need the exported "touch" file. I have it here if you do. PM me your email address and I can email it to you if so.
I really hope this works.
Let me know!
What do you think about this forum? Let us know by doing this short survey.
Just go to Settings > System > Display and you will be given the option to calibrate the display. Make sure to use the stylus when you do this. If you use your fingers the stylus will be off when you use this afterwards.
Hi Markus,
Thanks for the reply, but that is not my situation.. One of the calibaration point (Right side bottom corner ) on my Xperia X2 screen has been dead.. So after a hard reset am not able to align the screen.. I have done some tricks and now I am able to bypass the screen alignment.. But the screen is not responding to the touch request properly, so we need to insert the correct calibration data directly into the registry inorder to work it again( as we are not able to input the calibaration values / align the sreen through touch using stylus or somthing )... Thats why am requesting the calibration data.. I think, It is under HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\TOUCH.. I need all the values under it, so please simply export the values and share it please...
Any help would be gratefully appreciated..
Thank you,
Regards,
Sujith Chand
Ah, I see. Sorry to hear that.
We do not support that unfortunately so I cannot get you those data.
You could try to visit XDA Developers' Forum and see if someone there can help you. They usually can help with any techy stuff like this.
If they cannot I can only suggest you try to reinstall the software using Update Service. If that doesn't fix the problem you need to send the phone to a service center to get it fixed.
Contact the regional Sony support office if you want to do this.
http://www.sonymobile.com/global-en/support/contact-us/
Markus, this is very bad.. As I am one of your valuable customer, you have to provide these values.. I have already checked and posted some threads on XDA but it didn't help me yet.. Also I have contacted MS for this, they instructed me to contact you inorder to get the values... I have already visited the local SE service center, they told me that, they can fix the issue only by replaceing the touch screen, it cost me around 5000-6000 INR.. Since I am not in a postintion to invest this much amount for this phone again, someone please share the values..
Thank you,
Regards,
Sujith Chand
This is normally outside the support we provide and I cannot promise I will be able to get this information - but I will do my best to see what I can find. Let me get back to you.
Ok thanks! Hope you can find the values!
I contacted the developers who said they could not access the drivers needed - but - they did a quick search and found this:
[HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\TOUCH]
"CalibrationData"="504,507 753,258 749,755 223,755 268,258 "
I hope this is what you're looking for and that it will work. Let me know.
Hi Markus,
The values mentioned in the post is not for xperia x2, the values depends upon the touch screen size and its resolution ..
You can simply get the values from a working experia x2, please share it for me
Regarsd,
Sujith
Tell me how and where to find it and I will see if I can find an Xperia X2 lying around somewhere and try it.
The developers where not able to get the info. Are you sure it's that easy to just "get the values"?
