micro sd question!
SOLVED
Theliakos
Visitor
micro sd question!
hey guys ! can i buy a micro sd 16 gb class 10 for my xperia sp ?? will it be compatible ??
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Yes,a good choice.
alexdon
8 REPLIES 8
_alexdon_
Sandisk or sony class 10 of 16/32/64 could be fine.
alexdon
Uliwooly
it should work just fine
Theliakos
Visitor
but sony says till 32 gb !
_alexdon_
If you format it to fat32,it should work fine on 64 also.But you should go for 32,just for your calm.
alexdon
Theliakos
Visitor
ok thanksss
_alexdon_
Anytime.
alexdon
Theliakos
Visitor
i found this !
SanDisk Ultra MicroSDHC 16GB Android Class 10
guess its compatible ?? cause it says ultra !  it says it is the perfect match for android!
_alexdon_
Yes,a good choice.
alexdon
