Solved! Go to Solution.
This is an issue that has happened with a lot of Sony Xperia Android phones. Based on my experience, Sony has finally released a software version that addresses the problem.
Update to new software version 12.1.A.1.201 with Android 4.3, there appear to be improvements that make Bluetooth servicable if not perfect.
Thanks. This works now....however the phone now crashes at least once per day.
With .205 FW the volume is very low in my bluetooth handsfree!
The volume is so low that it's impossible to hear.
What can i do to increase the volume?
Help please.
ello everybody. Me too have this problem with 205 update. The volume is very low. What is the solution?
I'm not thinking of rooting my phone. But does rooting solve this problem?
I've got the same issue - before Android 4.3.
Now my HF set volume level is OK, what about update 12.1.A.1.207 - if it is available for you - install it and try...
Some help here please!
I'm following this issue since quite some time, currently on 12.1.A.1.205 and the TH volume when talking is useless.
Interested to hear if rooting would make a way around this issue.
