ME using Xperia Arc, i want to update it,im using Geniun Data cable,,so i try to update it from PC COMPANION but it doesnt work,
then i try it to update VIA WIFI ,so updating software downloded easily,but wen i start installing it ,so it takes a restart then it switched off.
den nevr get on automatically,
so when i turn it on manually,it show a sign,that Your softwares is not update,try again. !
Please tell me ,wt do i do .,to update it .. . . . im very Upset .!~
Solved! Go to Solution.
update your mobile with this
SUS ( Sony Update Service) ... download it and install it on your pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
ok Sir,,i 'll try it ,then i'll tell u ,is taht work or not. !`
Thanks
thanks bro,,it work..
now my Arc is up updated..!~
