hello to everyone...!
my arc s is not charging when is turned off
i turn off the device,and when i plug it in the charger,it shows me sony logo, -same time blue led- and then nothing.
i dont see the thunder any more as i supposed to ... 😕
could you please help me.? sorry for my bad english
Solved! Go to Solution.
Hi Nabeel,
thanks for sharing this tip. It worked like a charm, you're my savior! 🙂
One question, from which device your uploaded file comes?
best regards
fingerr
it's from my device
Xperia Arc S
Just for your info all the 2011 xperias share the same file so you could use the charger file in any xperia
But is it this somehow modified to work on root'ed phones or it's from stock ICS?
best regards
fingerr
Pure stock
Thanks for info Nabeel!
best regards
fingerr
after do this to my Arc s
the battery was charged on another phone and worked good now it was 52% and when connect the charger it become 0% and didn't start up
try charging it again
any other silution for this charging problem
is your phone rooted ?
are you facing the same problem ?
Means phone not charging while switched off
yes my phone is rooted .587
yes it can't charge while off and if my battery full or any xx% capacity get to 0% and never charger again
i can't charge my phone
my battery can charge in other phone
my battery take long time in phone to get low
phone work good with data cable and i can flash any firmware with flashtool or SUS or PcCom
Then do one thing, reinstall your phone's software using SUS
and then root your mobile using the guide here
Bakup before reinstalling if you wish
OK
i will try and tell you
thanks
