Solved! Go to Solution.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
That sounds quite strange. Have you tried to remove the battery for a while?
the only way it will rotate is if its connected to a Dock, otherwise only apps will rotate (whenever you open them)
If it all fail you can repair your phone with SUS or PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
It's hard to say what may have caused the problem. It might been some 3rd party app acting up or something else. If it works fine now, the behavior should not get back.
Please keep us updated if this happens again.
