Android OS - highest battery drain
SOLVED
Hey guys!
Android OS suddenly causes big battery problems. I asked the support already and they.told me to use the repair function of the companion. So i did, and the problem went slightly away but android os still drains the most (about 60 %). My battery lasts not a.whole day now...
Do u have a solving dor this annoying.problem?
Thanks for your answers!
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Yes,an app installed by you.
alexdon
6 REPLIES 6
_alexdon_
Do you use battery savers or task killers?
alexdon
No, nothing like that. Should i or could apps like that cause that problem?
_alexdon_
Yes,those apps will act up and wake up the phone.Boot the phone in safe mode and check if the same occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
Okay, i now restartet the phone in safe-mode, but the different applications which drain the battery are a record, arent they? Cause at first sight, Android OS is still on top with 53%.
Can i reset those, or will they reset if the phone is charged 100%?
Update:
I charged my phone fully, started in safe-mode anf now my battery seems to work longer, android os is still the top drainer (but i didnt use my phone that much in the meanwhile):
Android OS 33%
Android system 20%
Display 18%
(but display rises as it should be)
So an external app causes android os to freeze or something like that?
So it seems an external app causes
_alexdon_
alexdon
