Solved! Go to Solution.
Ignore the firmware on the guide just use the firmware from above - The rest is the same
You need to pop over to XDA and search for the relevant .ftf firmware file then using Flashtools manually flash this
Flash done successfully,
It took around 40 minutes to reboot the phone after flashing
