2,945  Views
Few things can boost your motivation and confidence than listening to your favourite music tracks during a workout. Lots of people like to get in their music bubble and double down: but how do sweat and tears affect your headphones?
What is an IP rating?
IP stands for Ingress Protection Marking, which classifies and rates the degree of protection provided by mechanical and electrical casings against dust, water and other intrusions. In other words, the IP rating will tell you how your product is designed to handle moisture, water and dust.
How do I check the IP rating of my device?
You can consult the IP rating in the specifications of each product. You can find the specifications tab on the upper left-hand side of your product page, next to the Product Highlights.
Alternatively, you can consult the specifications in the Help Guide or manual, which is also available on the product page.
If you can’t find any IP rating, your product is not officially resistant to dust or moisture (this includes sweat). Repeated exposure to dust and humidity could potentially damage your product. Always make sure to check the IP rating of your headphones before using them in physical activities that potentially drench you in sweat or expose you to lots of moisture or dust.  Sony’s Sports Wireless Headphones such as the WF-SP900 and the WF-SP700N are examples of headphones specifically designed for sports enthusiasts and have an IP rating.
IP rating overview
Protection from solid objects and dust
Protection from water
IP0X
No special protection
IPX0
IP1X
Protected against solid objects > 50mm in diameter
IPX1
Protected against dripping water
IP2X
Protected against solid objects > 12.5mm in diameter
IPX2
Protected against dripping water when tilted up to 15 degrees from the normal position
IP3X
Protected against solid objects > 2.5mm in diameter
IPX3
Protected against spraying water
IP4X
Protected against solid objects > 1mm in diameter
IPX4
Protected against splashing water
IP5X
Protected against dust; limited ingress (no harmful deposit)
IPX5
Protected against low-pressure water jet spray for at least 3 minutes
IP6X
Dust-tight
IPX6
Protected against heavy jet spray for at least 3 minutes
IPX7
Protected against the effects of immersion in up to 3.29 feet of water for 30 minutes
IPX8
Protected against the effects of continued immersion in water depths greater than 3.29 feet. The exact conditions are specified for each device by the manufacturer.
