Solved! Go to Solution.
Hi there
You will need to connect the E4100 up the following way:
I cannot see in the manual that your TV supported HDMI ARC (Audio Return Channel), that is the reason for the extra cable (optical)
Hi there
Can you please describe how you have connected the E4100 up to the TV, and what make/model the TV is please?
Cheers
Hi there
