Recently purchased, when connected via either optical or hdmi arc, the volume is just too low even when at max. Latest firmware applied. Volume via Bluetooth is fine and when at max is significantly higher than output via HDMI or optical. Any tips on how to resolve? I see a couple of other threads reporting the same problem, typically in the US. This unit was a UK one.
I tried everything. When I had a device though HDMI the sound was low, even at max it was not loud, the same device through optical was much louder with the same settings.
I am returning it to Amazon. On the USA thread the same problems was highlighted in October and there is still no fix, so I don't see one coming anytime soon.
Hi all
I have flagged this issue to Sony Support for them to investigate. Any info recieved will be posted back in this thread.
Cheers
Great. Let us see what Sony say.
What I do know, so far, is it depends on the source and the audio codec as only Sky HD box is quieter on most channels apart from some which are just as loud as the blu ray input. I believe this is down to the codec audio quality being sent to the soundbar depending on the broadcasted channel.
Funny you should say that in the USA it is something which is known as Sony got in contact with me and said the soundbar is functioning as designed. Well if there is a flaw then it is functioning as per the design flaw. I will contact them again with the link to this page and amazon.
Thanks
Hello all
Ive had some feedback from Sony today. It has been suggested that you increase the volume on the individual device itself and then control the volume via the HT-RT5.
If the volume is set to low volume on the SKY HD box, it will also output low volume from HDMI and Optical outputs….hence it gives the effect that sound bar volume output is low, even when set to maximum.
So, on a Sky remote control, there is a volume button. Can you try increasing this to maximum and see if this has any effect on the overall sound volume on the HT-RT5. Same applies for other devices such as a DVD player - increase the volume on the player itself firstly.
Please let me know how you get on
Cheers
Thanks for the update.
I can confirm this was checked initially but made no difference.
Thank you. Will feed this back. Would be great if some others could confirm too.
Cheers
Makes no difference for me either.
Hi guys
Im hoping if one or more can test the following:-
Sony would like you to play the same music file using a couple of different devices, such as playing the file on a bluray player and a smart phone via bluetooth.
Cheers
I'm not sure about other people but this isn't really an issue for me as I am only getting lower volumes on some Sky channels. Main channels I watch, Fox HD, Sky1 HD, BBC1 HD and Sky Atlantic HD are loud and clear for me. So I'm happy with the current setup. Would be good to see what others get from their results though.
