I have a Cyber shot DSC HX-100. I don't think it is a compact camera but that was the closest subject listed for a board. I need to purchase a replacement cable - the cable that connects the camera to my computer so I can download images. It may be a HDMI but I cannot see the diagram clearly so am not sure if that is the correct cable or maybe it is the Type 3c multi-connector? Can someone help me id the cable? And, if you know where I can get it that would be wonderful! THANKS!!
Hello @Trilmr20,
while the port is a so called "MULTI"-port, the cable used to connect the camera to your PC is a normal micro-USB-cable with data-transfer capabilities (usually all are).
You probably have a few of them lying around (at least I have) from e.g. a smartphone or other devices.
- Nic
