Cannot seem to set this up on my camera via the menus
Message was edited by: conkelly54
Solved! Go to Solution.
Hello conkelly54 - Welcome to the Sony Forums
With the HX10V camera, you are able to select a shutter speed of up to 30 seconds. This is controlled in the Manual Exposure Shooting menu on the camera and there are full instructions on the following page from the online user guide:
http://pdf.crse.com/manuals/4412220111/ENG/contents/02/03/07/07.html
As long as 'M' is selected on the mode dial, you will be able to press the 'dot' button on the control wheel and then rotate it to choose between 1/1600 of a second and 30 seconds.
Thanks,
Simon
Thanks,
Simon
Hi conkelly, welcome to the Sony Forums
You don't need to access any menus really, just set the mode dial to M (manual) and select your shutter speed (up to 30s) using the control wheel.
Cheers
Mick
Thanks Simon
