Hi,
Can some body share recovery discs of Sony VAIO FW 31e?
Regards,
Vikas
This is the accessory section in the German part of the Club Vaio.
Pls post questions which are English into the English part of the forum.
Regarding your problem, it is not allowed to share those disks, but you can demand new recovery from Vaio Link Support for 40€ only.
Hi Vikas,
You should be able to create a set of recovery disc's by doing the following:
Click Start, All Programs, then Vaio Recovery Center..
Click Continue on the User Account Control window
Select Create Recovery Disc then press Start..
If you have removed you're Vaio's hidden HDD recovery partition then you can purchase a set of recovery disc's by contacting Sony Vaio support, use the following link to find the contact details: Sony Vaio Support
