Help re: my old Sony Hi-8 camcorder
SOLVED
profile.country.en_GB.title
ChrisK10
Visitor
My old Sony Hi-8 camcorder was stolen in a burglary many years ago and I don't have any record of the make. It used the larger cassettes which are 95 x 60mm. I'd like to be able to get hold of an old camcorder which can play these tapes (eg on Ebay) so that I can upload them onto my computer and ultimately to DVD. Can anyone help as to the likely model number of the camcorder so I can try to buy one?    Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
All Hi-8 (and Video 😎 cassettes are a standard 95 × 62.5 × 15 mm so any Hi-8 camcorder should suit your needs.
There are several Sony CCD-TR and CCD-TRV models on eBay: -
http://www.ebay.co.uk/sch/i.html?_nkw=sony+hi8+camera&_sacat=0&_odkw=sony+hi-8+camera&_osacat=0&_trk...
Unfortunately, the EVO-250 Video Player/Recorder Deck is a bit more costly!!
http://www.ebay.co.uk/itm/PLAY-Hi8-Video8-Video-8-8mm-Tapes-w-Sony-EVO-250-Player-Recorder-VCR-Deck-...
:thinking:
4 REPLIES 4
Blencogo
:thinking:
ChrisK10
Visitor
Hi Glencogo
Can you tell me how the CCD-TR and CCD-TRV differ; ie does one giver a better quality image than the other or will they both fit my requirements to the same extent.
Many thanks
Chris
Blencogo
Hi Chris.
Not quite sure of the differences apart from age.
Just make sure you get a Hi8 model as many TRV models are Digital8 or Mini-DV format tapes - these will not be suitable as they use a Digital Video encoder..
:thinking:
ChrisK10
Visitor
Hi Blencogo
I did eventually manage to get hold of a TRV46E  camcorder on ebay and have been busy uploading my old cassettes to my PC. The  first one copied ok but unfortunately I tried to improve the quality of the  second by using an old cleaning tape (probably 18 years old) in the camcorder,  and since then I am getting audio distortion, though the video signal is good. I also  hear this if I replay the tape which originally downloaded ok, so it is not a  problem with the second tape. I assume the problem is due to using the cleaning  tape and that this is deteriorated and depositing particles on the audio head. I  will buy a new cleaning tape and hope this reverses the problem. But also I have  removed the cassette compartment cover on the camcorder to see whether I can see  any muck on the audio head. But I don't know which is the audio head. Is this part of the video  head, and would you advise attempting to clean it, eg with a q tip?  I am  reasonably technically competent.
Thanks again for all your help
Chris
