SONY tv android and vpn app problem
profile.country.GR.title
teligal
Explorer
I have the Sony TV KD 55xf9005 and I have installed the kaspersky vpn, but when I open it, it appears in a small part of the screen (see the photo), and I can't make any adjustments. Is there a way to fix this?
10 REPLIES 10
graygerman
Member
looks maybe like the app is designed for mobiles only and not actually tv so the resolution problem and aspect ratio is probably designed for a mobile screen, i may be wrong, but ive seen android mobile apps only open up like this on the tv, you could try altering the tvs aspect ratio, if you have that set on auto try it on zoomed
teligal
Explorer
I searched but couldn't find an aspect ratio setting on the TV, so I can't try it.
TheGOAT
@teligal I think it will not be adjusted, you can try deleting and redownloading it, if the same issue happens so it's clearly the App is not designed for a TV.
teligal
Explorer
i did that too, but unfortunately nothing happened. It's a shame because I bought this application in order to install it on TV and a tv box. It was successfully installed there, but not on TV.
MaggieGreene
Hi @teligal, what is your TV model name? You can use this link to help you locate the model name: https://www.sony.co.uk/electronics/support/articles/00248604
teligal
Explorer
i told you in the first post....KD 55xf9005
TheGOAT
@teligal Well, the best option is to contact Kaspersky's software creators to address that issue.
teligal
Explorer
I have already done it, they told me that it does not work with tv and android box.
I installed it on an android box and it works without any problems.
On television, however, it appears as shown in the picture.
Finally they told me to ask on the sony forum, if there is a solution!
TheGOAT
@teligal Well, if anyone here has a solution, he/she will mention it. For the meantime, what I really suspect that's it isn't an issue from the TV as you mentioned it worked when you installed it on an android box. It's an integration issue from Kaspersky's software creators.
