Sony Bravia won't turn off
SOLVED
CatherineAnne
Explorer
My new (roughly 2 months old) Sony Bravia won't turn off - either with the remote control or by pressing the power button on the back of the TV for several seconds.
The remote control is working to change channels etc, so I assume the batteries don't need changing.
Is it safe to unplug the TV as there seems no other way of turning it off?
1 ACCEPTED SOLUTION
Accepted Solutions
IamNic
Hi there @CatherineAnne,
yes, you can safely unplug it.
I assume the "ShutDown" command is frozen/stuck on the software side.
After unplugging it, leave it disconnected for a few minutes before plugging it back in and report back, if the issue arises again.
- Nic
13 REPLIES 13
IamNic
- Nic
CatherineAnne
Explorer
Thanks for your help Nic - that did the trick!
IamNic
Hi @CatherineAnne,
you're very welcome.
- Nic
Todd543
Explorer
Hi my sony bravia tv won't turn on it's sruck in a loop,how do I restart it?, tried unplugging it no joy,tried holding button for six seconds to restart..still nothing two weeks with no tv I'm getting desperately stressed out!.
I can’t turn off the TV or change channels with the remote controls
jandol
Explorer
Same happens with our 1 day old Bravia. I switch off with the remote or the power off button but tv comes on again in about 5 minutes.How can I unfreeze the Shut Down in the software or do I have to unplug everytime i shut down? Is it a fault with the TV?
After doing a factory reset and unplugged a bunch of time I noticed the green light flashing on my Roku.  Found Roku remote trapped in recliner pushing the buttons.  Took it out and Viola...  What a relief.  Couldn't see the forest for the trees.
Tjell07
Explorer
I also have the problem of the TV not staying off when switched off either with the remote or the buttons on the TV. The suggested solution doesn't work either.
Johnbgarner44
New
