KD 65XH9505 Low dialoge volume in movies
SOLVED
profile.country.GR.title
CharisP
Explorer
Καλημέρα,
Έχω την KD 65XH9509. Παρατηρώ πολύ χαμηλή ένταση στην ομιλία σε σχέση με την ένταση του ήχου της μουσικής και του περιβάλλοντος μιας ταινίας. Υπάρχει κάποια ρύθμιση που μπορεί να γίνει;
Ευχαριστώ
1 ACCEPTED SOLUTION
Accepted Solutions
CharisP
Explorer
It seems to be app configuration problem. I changed the sound settings of the app that i use and the voice is better now.
Thank you
8 REPLIES 8
CharisP
Explorer
Hi,
I have the KD 65XH9505. I notice very low volume in the speech in relation to the volume of the music and the environment of a movie. Is there any adjustment that can be made?I have already try the zoom to voice setting.
Thank you in advanced.
Joe_Dohn
Specialist
Have you tried the audio customisation settings?
CharisP
Explorer
Hi,
Thanks for your answer. I have already tried some settings but the voice volume is still low when the enviroment sound of the movie is high.
Is there any setting that you propose?
Joe_Dohn
Specialist
I'd try acoustic auto calibration first, then maybe adjusting the sound mode (dialogue, cinema, etc.)
CharisP
Explorer
Thank you
Joe_Dohn
Specialist
Glad to hear it was resolved for you!
It'd be really helpful to others if you mention the app you're using and the settings you changed so others can try your suggestions ^^
- JD
CharisP
Explorer
Of course. The app is Kodi. And the sound settings that you can do is from the menu during the movie.
Joe_Dohn
Specialist
Thanks a lot for the information! ^^
