Hello, l disconnected my headphones &TV to move them, & cannot reconnect them. I need to use the headphones as l have a hearing problem, but also keep the TV speakers on for my wife. If l plug the jack plug into the TV it switches the TV speakers off.
It worked perfectly before l unplugged it! I would appreciate your help. Regard, Robert.
[mail address removed due to privacy guidelines]
Solved! Go to Solution.
Hi, try unplugging the TV from the mains for two minutes and disconnect any external device, connect them back then make sure the headphones speaker link is on again while the headphones are connected.
Hi,
Please enable "Speaker/Headphone link" in the sound settings - this should solve your issue.
Cheers
Peter
Hello
I am still trying to connect my Sony Headphone to my Bravia Sont TV, and to keep my TV speaker on for my Wife. Would appreciate your help. Regards Robert.
