Android TV issue
GELÖST
theweblord2000
Neues Mitglied
Android TV issue
I usually power off at the plug socket each time I finish using my Tv, For my newly purchased Android Sony TV I can't work out how to power on and go straight to viewing my Sky HD, after the boot sequence to goes to the Home menu.
How do I set the power on preference to be HDMI 1 which is my Sky box? I was able to do this on my previous Panasonic.
Thanks
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Anonymous
Nicht anwendbar
Hi there
If you enable 'Control for HDMI' on the Sky HD box and enable Auto TV on in the Bravia Sync settings.  Then all you have to do is switch the Sky box on, and the TV will switch itself on and change to the correct HDMI input.
Cheers
Lösung in ursprünglichem Beitrag anzeigen
2 ANTWORTEN 2
Anonymous
Nicht anwendbar
Hi there
Cheers
theweblord2000
Neues Mitglied
Cheers now working thanks.
