sd card and sony memory stick pro duo
distill123
Hi
I have just got a 2nd hand A450 and note I can use either card (so long as I put the switch to the correct card in use) so if I use a sd card with switch in correct position can I also have a sony memory stick pro duo in the other slot and when the sd card is full just flick the switch over to the sony memory stick.
Cheers
0 RESPUESTAS 0
