Memory Stick Mark 2 or Memory Stick PRO-HG Duo HX - which one is better for Full HD recording 17MB/s in my NEX-5 ?
Solved! Go to Solution.
Both work just as well as each other. So far testing them both out, I have had no differences in performance.
Transfer speeds may be limited by the camera body if using USB direct from it so you could also try a high speed USB memory card reader when transferring to PC.
