The instructions for performing the update from v1.3 or earlier to the latest v1.4 seem to say that WIndows 7 64-bit is not a suitable OS from which to run the update. Is this true? Has anyone dared to try the update from Win7 64-bit?
If I'm reading the instructions correctly, it shows a very poor understanding of what is currently being sold with recent computers. ALL those I have looked at have had a 64-bit OS installed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Message was edited by: kenmonk
Hi kenmonk and welcome.
You will be fine! If you look again at the System Requirements: -
Windows XP* SP3Windows Vista** SP2Windows 7 SP1
Notes:
64-bit is not supported IN XP ONLY
Starter is not supported in Vista ONLY
Windows 7 64-bit and 32-bit ARE supported - so you will be OK.
Have any of you an idea about Mac OS 64 bit, because there is also written that it does not work. ?
Sorry. Not to change the subject. !
Hello hewestb - Welcome to the Sony Forums
Could you please let me know exactly which version of the Mac operating system you are using. I am aware that in certain Mac environments, it is possible to boot in 32 bit mode (with certain limitations) so if you give me as much information as you can, I will look into this further for you.
Thanks,
Simon
