There is a rumour that the A65/77 will get a firmware update on the 29th March.
Expanded the number of automatic compensation compliant lenses (6 lens)
24/2 ZA
85/1.4 ZA
135/1.8 ZA
70-300/4.5-5.6 G
DT35/1.8
DT50/1.8
Improvement of response
・Improvement of response for Auto review (Display of [Processing] will not appear)
・Shorten time lag between power SW operation and power off
・Improvement of response for front/rear dial and mode dial
・Improvement of response in play back mode
Improve AF response with 500mmF4 lens
Improvement of AF accuracy for low contrast objects
Improvement of compatibility of Minolta lens
[Konica Minolta] 1.4X TELE CONVERTER APO X [Konica Minolta] AF APO 300/2.8
[Konica Minolta] 2.0X TELE CONVERTER APO X [Konica Minolta] AF APO 300/2.8
[Konica Minolta] 1.4X TELE CONVERTER APO X [Konica Minolta] AF APO 600/4
Source: Sonyalpharumors
Solved! Go to Solution.
Hallo gimp69,
Welcome to the Dutch Sony forums. Please note that this is a Dutch language forum and it will be easier for users to respond to you if you post your message in Dutch. For questions in the English language please access the English forums by clicking the language selection option at the top right of your screen, next to the Sony logo.
Kind regards,
Tycho Moderator
Hallo gimp69,
Welkom op de Nederlandstalige Sony forums. Dit is een Nederlandstalig forum en het is makkelijker voor de gebruikers om je te helpen als je je berichten in het Nederlands plaatst. Voor vragen in het Engels kun je terecht op de Engelse forums, klik hiervoor op de taal selectie knop rechts bovenaan je scherm naast het Sony logo.
Met vriendelijke groet,
Tycho Moderator
I am posting on sony.co.uk like I usually do and all the posts here are ENGLISH. There is the UK flag at the top of the page too, it's not my first time here and I certainly don't see anything in Dutch!
Hallo gimp69
Mistakenly asked to post in another language. Apologies for the confusion caused.
Kind regards
Tycho
Moderator
