I'm from Bangladesh. A-mount leses is not available in here. And, frankly speaking I'm a student for that I can't afford to buy a new A-mount lens from Amazon.com or, ebay etc.
I just found a old Minolta 35-80mm. lens. Is it wrok on my Alpha A58 device without Adopter? Because, Adoptor don't get the best picture quality.
Hi there,
You may be able to use your Minolta lens without an adapter, but this will depend on the lens itself. Some Minolta lenses are fully compatible with no need for an adapter, some require an adapter, and some will not work with your camera at all.
You can find out more, and hopefully learn whether or not your particular model is compatible, via the following link: http://bit.ly/2AjCmGs.
We hope this helps. Please let us know if you have any further questions.
Thanks,
Owen
