Hello, I have a problem with audio latency, I'm recording to Quick Time Player, for example, and the audio is delayed. I use the original cable. Thank you for the advice.
Hello @Fibi73,
what happens if you record in-camera? Is the audio in sync then?
If so, it is an issue with the software you use.
- Nic
